Does Ubuntu uses Python for something or it is a pre-installed application like other? I am asking because I would upgrade it and don't want to damage my system.
Hi @Juandev,
Ubuntu is using preinstalled Python. Try this command in terminal to check reverse dependencies on Python: apt-cache rdepends --installed python3 python3.10
. Ubuntu 22.04 is put together and tested with Python 3.10, and /usr/bin/python3
shall point to python3.10. You may have different Python versions installed simultaneously, but keep /usr/bin/python3
untouched.
Hope this helps.
