Dvd player advice requested
I found this in a pawn shop. It is only $7.99.
But I do not have the AV connectors on my computer.
Is there some kind of adaptor?
Do you think it is a good buy?
That is a DVD player for plugging into a TV.
You need at least this one connector for the video portion only:
You need another adaptor for the audio:
Thanks Eric.
I will save up for the DVD burner like you suggested.
