yes you can, it re-installs the package again!.
Do you mean remove and reinstall without rebooting/log out session, with the same terminal opened?
Best regards!!
I mean that the command will do what it says on the box and so yes!, re-install BUT reboot for that just in case scenario!.
I will be in holidays next week, I think I’ll wait to try then. It’s the home computer, if something fails I’ve to fix quickly…
Best regards!!
