Exfat filesystem
Have exfat-utils and exfat-fuse installed by default.
all small digital cameras format with this filesystem and when you insert a memory card or plug camera in you cant mount device. you can go to synaptic and install exfat-utils and exfat-fuse to get it to work.
Brilliant. Thank you Dave
@david_b Good catch. Will be included in 15.04 final :slight_smile:
