After Running $ sudo forecfg, when I try opening SSRecorder using icon in firetools window, the SSR app does not open but the PID shows it is running;
PID = 13785 in firetools monitor
PID = 13789 Zombie process in System Monitor
When I open SSRecorder using Applications icon, or panel icon the SSR app does not open but Firetools and System Monitor both show it is running, and System monitor shows only Zombie processes.
When SSR is opened with the command; $ firejail simplescreenrecorder, the App does not open but Firetools and System Monitor both show it is running, and System monitor shows only a Zombie process. Firetools monitor pid = 15439 : System monitor pid zombie= 15443:
The only way to open the SSRecorder app is with the following command;
$ firejail --private --noprofile /usr/local/bin/simplescreenrecorder.
######@######:~$ sudo firecfg
[sudo] password for ######:
Removing all firejail symlinks:
Configuring symlinks in /usr/local/bin based on firecfg.config
VirtualBox created
Xephyr created
atril created
atril-previewer created
atril-thumbnailer created
celluloid created
cheese created
cvlc created
darktable created
dnsmasq created
enchant created
enchant-2 created
enchant-lsmod created
enchant-lsmod-2 created
engrampa created
eom created
evolution created
ffmpeg created
ffmpegthumbnailer created
ffplay created
ffprobe created
firefox created
gjs created
gucharmap created
kdenlive created
less created
libreoffice created
localc created
lodraw created
loffice created
lofromtemplate created
loimpress created
lomath created
loweb created
lowriter created
mate-calc created
mate-calculator created
mate-color-select created
mate-dictionary created
mpv created
obs created
patch created
pdftotext created
pluma created
qt-faststart created
redshift created
rhythmbox created
rhythmbox-client created
seahorse created
seahorse-daemon created
secret-tool created
signal-desktop created
simple-scan created
simplescreenrecorder created
soffice created
ssh created
strings created
torbrowser-launcher created
transmission-gtk created
virtualbox created
vlc created
wget created
xcalc created
yelp created
youtube-dl created
Adding user adastra to Firejail access database in /etc/firejail/firejail.users
User ###### already in the database
Loading AppArmor profile
Fixing desktop files in /home/user/.local/share/applications
vlc.desktop created
signal-desktop.desktop skipped: file exists
io.github.celluloid_player.Celluloid.desktop skipped: file exists
caja.desktop skipped: file exists
darktable.desktop skipped: file exists
org.gnome.Cheese.desktop skipped: file exists
When I try opening SSRecorder using icon in firetools window, the SSR app does not open but the PID shows it is running;
######@######:~$ firejail simplescreenrecorder
Reading profile /etc/firejail/simplescreenrecorder.profile
Reading profile /etc/firejail/disable-common.inc
Reading profile /etc/firejail/disable-devel.inc
Reading profile /etc/firejail/disable-exec.inc
Reading profile /etc/firejail/disable-interpreters.inc
Reading profile /etc/firejail/disable-passwdmgr.inc
Reading profile /etc/firejail/disable-programs.inc
Reading profile /etc/firejail/disable-xdg.inc
Reading profile /etc/firejail/whitelist-usr-share-common.inc
Parent pid 15439, child pid 15440
Blacklist violations are logged to syslog
Child process initialized in 80.95 ms
Warning: an existing sandbox was detected. /usr/bin/simplescreenrecorder will run without any additional sandboxing features
==================== SSR started ====================
SimpleScreenRecorder 0.3.11
Compiled with GCC 9.3.0
Qt: header 5.12.5, lib 5.12.8
libavformat: header 58.29.100, lib 58.29.100
libavcodec: header 58.54.100, lib 58.54.100
libavutil: header 56.31.100, lib 56.31.100
libswscale: header 5.5.100, lib 5.5.100
[CPUFeatures::Detect] CPU features: mmx sse sse2 sse3 ssse3 sse4_1 sse4_2 avx avx2 bmi1 bmi2
[ALSAInput::GetSourceList] Generating source list ...
[ALSAInput::GetSourceList] Found plugin: [samplerate] Rate Converter Plugin Using Samplerate Library
[ALSAInput::GetSourceList] Found plugin: [speexrate] Rate Converter Plugin Using Speex Resampler
[ALSAInput::GetSourceList] Found plugin: [jack] JACK Audio Connection Kit
[ALSAInput::GetSourceList] Found plugin: [oss] Open Sound System
[ALSAInput::GetSourceList] Found plugin: [upmix] Plugin for channel upmix (4,6,8)
[ALSAInput::GetSourceList] Found plugin: [vdownmix] Plugin for channel downmix (stereo) with a simple spacialization
[ALSAInput::GetSourceList] Found plugin: [usbstream] USB Stream Output
[ALSAInput::GetSourceList] Found card: [hw:0] HDA Intel PCH
[ALSAInput::GetSourceList] Found device: [hw:0,0] HDA Intel PCH: ALC293 Analog
[PulseAudioInput::GetSourceList] Generating source list ...
[SourceNamesCallback] Found source: [alsa_output.pci-0000_00_1f.3.analog-stereo.monitor] Monitor of Built-in Audio Analogue Stereo
[SourceNamesCallback] Found source: [alsa_input.pci-0000_00_1f.3.analog-stereo] Built-in Audio Analogue Stereo
######@######:~$ firejail --private --noprofile /usr/local/bin/simplescreenrecorder
Parent pid 16223, child pid 16224
Child process initialized in 8.28 ms
In firejail monitor PID=16223, System monitor PID=16231;
