I can’t seem to find any way to do a simple color correction on a single display in Ubuntu MATE. The Control Center doesn’t seem to have the Colors section under hardware. Is there a simple way to dumb down the bluish cast that the MSI GS70 is notorious for? I have dual monitors so really all I care about is getting them to look similar enough and not actually calibrated. Thanks!
It seems that the current color management for MATE isn’t being worked on anymore. However, it was a fork of gnome-color-manager
, so you might see if that does for you.
