Hey guys/gals, I have a dedicated machine which is for my kids to game on… Running Ubuntu-MATE 15.04. What I want are suggestions for a cheap but decent gaming headphone/mic set so I don’t have to listen to them. Right now it’s external speakers and mic. Any suggestions would be great… Need to be Linux friendly of course.
I have a Logitech H600 usb wireless. Works great on both the mic and headphones. Nice and clear plug’n play.
Found this one:
http://www.logitech.com/en-us/product/6625
Seems cheap enough!.
I haven't checked out this site:
http://headset.mymom.info/logitech-headset-wireless/logitech-stereo-headset-h110-driver/
Definitely need to go wired… They will never keep it charged.
I know where you are coming from man. Been there and done that with mine.
I have a pair of Creative ChatMax HS-420. The sound is “good enough” but they have 3 useful attributes:
Microphone is detachable (so, if it isn’t needed, it needn’t get in the way);
Microphone mute switch and volume slider in a box on the cable;
Two 3.5mm plugs (one for microphone, one for headphones) - no USB.
One cannot argue with that for £13 on Amazon UK!
Hi guys,
I’m looking for a headset and your propostions seems really good.
But i wasn’t able to see how they are connected.
I’m looking for a all-in-on headset with a single jack connector to plug into my ultrabook.
For example the Creative doesn’t fit in my search.
Thanks
try this:
You will still have to look for a suitable headset but with an adaptor, you have a far bigger choice!.
Thanks, i found that solution later surfing on web vendors. ^^
