Geany no longer displays underscores
Since the migration to Ubuntu 20.04, Geany no longer displays underscores.
Any fix?
Geany forum has no answer.
I thought this as well back in 18.04 but it was theme related.
As you can see, if you zoom in maximum, they are there; line 1, line 3. Line 2 shows hyphen and line 4 shows the blinking cursor.
Interestingly if you zoom with your mouse in-and-out-and-back certain zoom levels with reveal them more over others.
This is on a 4K screen.
It'd be nice if they were a bit more visible from start up but I've learned to live with this.
Changing Tools > Configuration Files > filetypes.common to include
[styling]
line_height=0;2;
solved this bug !
@fixit7 config change had no affect for me, same behavior :disappointed:
Are you using UM 20.04?
Send an email to [email protected] .
They are Geany experts.
