Helo there,
I just upgraded from 16.04 to 17.04 , currently watching movies and all seeing pixalation of the same. Graphics is not rendering properly for720P or better quality movies.
watched these movies in great quality before the upgrade.T
Appreciate if somebody can help
Thanks
Jacky
Are you using the same media player now as you did before? If so, try a different media player. Just to see if it’s related to the media player or to the OS.
thanks for the reply,
Was watching the movies online like youtube.
Hello @Jacky_chan
Maybe you can try changing Window manager
in MATE Tweak
in Windows panel from Marco (Software compositor)
to Marco (Compton GPU compositor)
thanks
I installed mate tweak and changed to Macro Compton GPU compoitor but unfortunately no difference
Please help
Is there anyway i can degrade to 16.04 Please help
how did you upgrade from 16.04 to 17.04 in the first place?
Also what do you mean you installed MATE tweak, it’s already comes preinstalled.
Which graphic card you use?
Helo there
I enabled the option to notify newer distros , thats how seen 17.04 and upgraded the machine.
Not sure the graphic card it should be onboard card for my laptop i beleive.
Please advise
Thanks
[quote=“Jacky_chan, post:3, topic:13234”]Was watching the movies online like youtube.[/quote]Which browser? Because what you’re describing is kind of odd for it to be caused by the upgrade. I’m going to guess that with the upgrade came an upgrade for whatever browser you’re using and that is causing the issue.
Just a guess though.
You may want to try to boot from a 17.04 live image and see if the same problem occurs there to exclude that it’s an issue with the upgrade process.
