MATE has been successfully installed along with "plain vanilla" Ubuntu but during boot there is no indication which option to choose. What is cmd needed to modify GRUB loader to show "MATE' and also make it the default ? Thanx.
[quote="Newbie_Bob, post:1, topic:19845"]along with "plain vanilla" Ubuntu
[/quote]
Bob
That might mean something to you, but maybe you could expand on that comment
eg....you have only one drive
partition one as distro=Ubuntu (not Mate)
partition two as distro=Ubuntu-Mate
post the results of this command pls $ sudo blkid
UNTIL you get a better reply I urge you not to attempt to modify scripts
at /etc/grub.d especially the one called 10_linux
Its normally OK to modify /etc/default/grub
but in any case....your change will not take effect until you run $ sudo update-grub
so until you get a reply.....I plan to create a 40_custom script for you
Do you know when you look at your blkid output you are likely to see UUIDs
but 40_custom can use LABELs and its more intuitive
let me give an example THESE ARE MINE NOT ORIGINAL POSTERS
/dev/sda1: LABEL="s1" UUID="ec2e1b95-56d0-4893-95a7-0f52445dcdff" TYPE="ext4" PARTUUID="a35f4ef3-01"
/dev/sda2: LABEL="sswap" UUID="0456b0ee-6be6-4356-8dc1-386ee06e1528" TYPE="swap" PARTUUID="a35f4ef3-02"
/dev/sda3: LABEL="s3" UUID="4008f440-7790-4da4-a36e-4b8f7855114e" TYPE="ext4" PARTUUID="a35f4ef3-03"
/dev/sdb1: LABEL="t1" UUID="22d92423-8eab-4785-820c-a135115baece" TYPE="ext4" PARTUUID="378f30fb-01"
/dev/sdb2: UUID="3cbab6cd-2b68-4d72-b1bf-9ea37f1b828f" TYPE="swap" PARTUUID="378f30fb-02"
/dev/sdb3: LABEL="t3" UUID="992321db-95a9-4877-ac3b-56c8eeb078c8" TYPE="ext4" PTTYPE="dos" PARTUUID="378f30fb-03"
/dev/sdb4: LABEL="t4" UUID="822402a3-1910-4514-8cc0-20983a81d20a" TYPE="ext4" PTTYPE="dos" PARTUUID="378f30fb-04"
you can change your labels with a sudo command
$ sudo e2label /dev/sda1 my-new-label
(should report new label name)
be aware....I am assuming you are on an ext2 ext3 or ext4 file system
Provided that you have no chance to choose which ubuntu flavour to boot in, what makes you to believe that you have installed UM side by side with legacy Ubuntu and not on top of legacy Ubuntu?
Hi Gene: apparently BOTH flavors have been installed but i cannot tell from description provided which is which. One option boots "plain vanilla", another option boots MATE. Now if i could modify GRUB wording on screen and make MATE the default i will feel really good abt Ubuntu.
Gene: Thanx for the tip. Apparently the GRUB Customizer works well (after some trials) but i now also have a Grub CUSTOMEIZER (yes CUSTOMEIZER) application which doesn't appear to be related to GRUB. Instead it seems to be a file search tool. WHAT IS GOING ON ?? Are the tech gremlins loose ? If so they must have remained dormant in the system unit after Windoze 10 was removed
Sorry, Bob, I have no idea how your system could catch 'customeizer'...
I've downloaded package from grub-customizer PPA and looked at its contents. There was nothing like 'customeizer'.
Gene
