Hi!
How can I fix this?
gvfsd-metadata: g_udev_device_has_property: assertion 'G_UDEV_IS_DEVICE (device)' failed
I read I need to patch "meta-daemon.c"
But I can't find that file on Ubuntu Mate 18.04 in Caja via "search"...
Here is the patch I found here:
Patch:
@@ -319,13 +319,15 @@ handle_get_tree_from_device (GVfsMetadata *object,
g_once_init_leave (&gudev_client, g_udev_client_new (NULL));
device = g_udev_client_query_by_device_number (gudev_client, G_UDEV_DEVICE_TYPE_BLOCK, devnum);
if (device != NULL)
if (g_udev_device_has_property (device, "ID_FS_UUID_ENC"))
res = g_strconcat ("uuid-", g_udev_device_get_property (device, "ID_FS_UUID_ENC"), NULL);
else if (g_udev_device_has_property (device, "ID_FS_LABEL_ENC"))
res = g_strconcat ("label-", g_udev_device_get_property (device, "ID_FS_LABEL_ENC"), NULL);
g_clear_object (&device);
#endif
gvfs_metadata_complete_get_tree_from_device (object, invocation, res ? res : "");
What must I do, which file must I edit to add the patch?
Please help, thanks!
