Help running dreamboxEDIT in wine
Hi all,
I'm trying to use wine to run dreamboxEDIT.exe.
I am following This Guide.
All seems to go well and when I run the .exe in wine with the command
$ wine dreamboxEDIT.exe
It runs but the initializing window doesn't clear and partially sits in the middle of the screen until I close the app.
I get the following in my terminal but not sure what to make of it.
wine reamboxEDIT.exe
fixme:wtsapi:WTSRegisterSessionNotification Stub 0x400c8 0x00000000
err:winediag:SECUR32_initNTLMSP ntlm_auth was not found or is outdated. Make sure that ntlm_auth >= 3.0.25 is in your path. Usually, you can find it in the winbind package of your distribution.
err:listview:LISTVIEW_WindowProc unknown msg 109d wp=00000000 lp=00000000
Any help appreciated.
