Help with cat statement
I need help with this cat command.
I am trying to find messages in syslog.
cat /var/log/syslog | grep -i bluetooth or journalctl | grep -i bluetooth
grep: or: No such file or directory
grep: journalctl: No such file or directory
The OR operator is the vertical bar | and needs to be escaped. Following your example,
cat /var/log/syslog | grep -i "bluetooth | journalctl"
The -i switch should make finding bluetooth case insensitive but it did not find Bluetooth lines in the file?
remove the spaces before and after |
file andy contains:
just a line
This line has something
this is bluetooth
this is uppercase Bluetooth
command
> cat andy | grep -i "bluetooth\|This"
result
this is bluetooth
