Hi.
I’m new, apologies if I posted in the wrong place.
I am running UbuntuMATE on Ras-pi 3 (On Pi-Top)
I noticed an error during startup
● systemd-modules-load.service - Load Kernel Modules
Loaded: loaded (/lib/systemd/system/systemd-modules-load.service; static; ven
Active: failed (Result: exit-code) since Thu 2016-02-11 16:28:01 GMT; 1 years
Docs: man:systemd-modules-load.service(8)
man:modules-load.d(5)
Process: 121 ExecStart=/lib/systemd/systemd-modules-load (code=exited, status=
Main PID: 121 (code=exited, status=1/FAILURE)
Feb 11 16:28:01 charlie-desktop systemd-modules-load[121]: Failed to find module
Feb 11 16:28:01 charlie-desktop systemd-modules-load[121]: Inserted module 'i2c_
Feb 11 16:28:01 charlie-desktop systemd-modules-load[121]: Inserted module 'bcm2
Feb 11 16:28:01 charlie-desktop systemd[1]: systemd-modules-load.service: Main p
Feb 11 16:28:01 charlie-desktop systemd[1]: Failed to start Load Kernel Modules.
Feb 11 16:28:01 charlie-desktop systemd[1]: systemd-modules-load.service: Unit e
Feb 11 16:28:01 charlie-desktop systemd[1]: systemd-modules-load.service: Failed
Warning: Journal has been rotated since unit was started. Log output is incomple
lines 1-18/18 (END)…skipping…
Loaded: loaded (/lib/systemd/system/systemd-modules-load.service; static; vendor preset: enabled)
Active: failed (Result: exit-code) since Thu 2016-02-11 16:28:01 GMT; 1 years 11 months ago
Process: 121 ExecStart=/lib/systemd/systemd-modules-load (code=exited, status=1/FAILURE)
Feb 11 16:28:01 charlie-desktop systemd-modules-load[121]: Failed to find module ‘lp’
Feb 11 16:28:01 charlie-desktop systemd-modules-load[121]: Failed to find module ‘ppdev’
Feb 11 16:28:01 charlie-desktop systemd-modules-load[121]: Failed to find module ‘parport_pc’
Feb 11 16:28:01 charlie-desktop systemd-modules-load[121]: Inserted module ‘i2c_dev’
Feb 11 16:28:01 charlie-desktop systemd-modules-load[121]: Inserted module ‘bcm2835_v4l2’
Feb 11 16:28:01 charlie-desktop systemd[1]: systemd-modules-load.service: Main process exited, code=exited, status=1/FAILURE
Feb 11 16:28:01 charlie-desktop systemd[1]: systemd-modules-load.service: Unit entered failed state.
Feb 11 16:28:01 charlie-desktop systemd[1]: systemd-modules-load.service: Failed with result ‘exit-code’.
Warning: Journal has been rotated since unit was started. Log output is incomplete or unavailable.
How do I fix these errors?
I also note that downloads will not install - is this due to these errors or something else.
please go easy on me, I’m new to all this hehe
