can anyone tell me how to remove the long hardware device name info in the picture
you appear to have 2 connections listed, if you don't use both of the Ethernet adaptors, delete one from network settings:
I hope it helps.
Thanks for the response
Deleting a connection doesn’t help I’ve removed all but one connection and it still shows
is there no better way of removing the names in the configs
I don’t know to be honest, take a look at “Name resolution” here:
https://help.ubuntu.com/lts/serverguide/network-configuration.html#name-resolution
To change the network hardware device name in the network manager applet
would appear to require a source code change. From applet-device-ethernet.c
if (multiple_devices) {
const char *desc;
desc = nm_device_get_description (device);
if (connections->len > 1)
text = g_strdup_printf (_("Ethernet Networks (%s)"), desc);
else
text = g_strdup_printf (_("Ethernet Network (%s)"), desc);
} else {
text = g_strdup (_("Ethernet Networks"));
else
text = g_strdup (_("Ethernet Network"));
