Home network file sharing problems
Having problems with file sharing over my home network and its between ubuntu 16.04 computers. Already tried the tutorials found on here any suggestion. When is this going to be fix or an update issued
to fix this problem? With the how to geeks on personal file sharing it doesn't get me any further then this. Yes, samba is installed.
Justin
Did you install caja-share from the software boutique? (Section ‘Servers’)
Cheers
What specific OS is that in the picture?
It is ubuntu mate 16.04. I just have it transforlmed into Macbuntu.
Had not tried that yet. Installing now and well see what happens.
Tried caja share no change. Was missing the libuser.conf file fixed that. think I maybe missing something simple. Here is the smb.conf file.
**#======================= Global Settings =======================**
**[global]**
**## Browsing/Identification ###**
**# Change this to the workgroup/NT-domain name your Samba server will part of**
**	workgroup = workgroup**
**	force user = mj**
**# server string is the equivalent of the NT Description field**
**	server string = %h server (Samba, Ubuntu)**
**# Windows Internet Name Serving Support Section:**
**# WINS Support - Tells the NMBD component of Samba to enable its WINS Server**
**#   wins support = no**
**# WINS Server - Tells the NMBD components of Samba to be a WINS Client**
**# Note: Samba can be either a WINS Server, or a WINS Client, but NOT both**
**;   wins server = w.x.y.z**
**# This will prevent nmbd to search for NetBIOS names through DNS.**
**	dns proxy = no**
**#### Networking ####**
**# The specific set of interfaces / networks to bind to**
**# This can be either the interface name or an IP address/netmask;**
**# interface names are normally preferred**
**;   interfaces = 127.0.0.0/8 eth0**
**# Only bind to the named interfaces and/or networks; you must use the**
**# 'interfaces' option above to use this.**
**# It is recommended that you enable this feature if your Samba machine is**
**# not protected by a firewall or is a firewall itself.  However, this**
**# option cannot handle dynamic or non-broadcast interfaces correctly.**
**;	bind interfaces only = no**
**#### Debugging/Accounting ####**
**# This tells Samba to use a separate log file for each machine**
**# that connects**
**	log file = /var/log/samba/log.%m**
**# Cap the size of the individual log files (in KiB).**
**	max log size = 1000**
**# If you want Samba to only log through syslog then set the following**
**# parameter to 'yes'.**
**#   syslog only = no**
**# We want Samba to log a minimum amount of information to syslog. Everything**
**# should go to /var/log/samba/log.{smbd,nmbd} instead. If you want to log**
**# through syslog you should set the following parameter to something higher.**
**	syslog = 0**
**# Do something sensible when Samba crashes: mail the admin a backtrace**
**	panic action = /usr/share/samba/panic-action %d**
**####### Authentication #######**
**# Server role. Defines in which mode Samba will operate. Possible**
**# values are "standalone server", "member server", "classic primary**
**# domain controller", "classic backup domain controller", "active**
**# directory domain controller". **
**# Most people will want "standalone sever" or "member server".**
**# Running as "active directory domain controller" will require first**
**# running "samba-tool domain provision" to wipe databases and create a**
**# new domain.**
**	server role = standalone server**
**# If you are using encrypted passwords, Samba will need to know what**
**# password database type you are using.  **
**;	passdb backend = tdbsam**
**	obey pam restrictions = yes**
**# This boolean parameter controls whether Samba attempts to sync the Unix**
**# password with the SMB password when the encrypted SMB password in the**
**# passdb is changed.**
**	unix password sync = yes**
**# For Unix password sync to work on a Debian GNU/Linux system, the following**
**# parameters must be set (thanks to Ian Kahan <<[email protected]> for**
**# sending the correct chat script for the passwd program in Debian Sarge).**
**	passwd program = /usr/bin/passwd %u**
**	passwd chat = *Enter\snew\s*\spassword:* %n\n *Retype\snew\s*\spassword:* %n\n *password\supdated\ssuccessfully* .**
**# This boolean controls whether PAM will be used for password changes**
**# when requested by an SMB client instead of the program listed in**
**# 'passwd program'. The default is 'no'.**
**	pam password change = yes**
**# This option controls how unsuccessful authentication attempts are mapped**
**# to anonymous connections**
**	map to guest = bad user**
**########## Domains ###########**
**# The following settings only takes effect if 'server role = primary**
**# classic domain controller', 'server role = backup domain controller'**
**# or 'domain logons' is set **
**# It specifies the location of the user's**
**# profile directory from the client point of view) The following**
**# required a [profiles] share to be setup on the samba server (see**
**# below)**
**;   logon path = \\%N\profiles\%U**
**# Another common choice is storing the profile in the user's home directory**
**# (this is Samba's default)**
**#   logon path = \\%N\%U\profile**
**# The following setting only takes effect if 'domain logons' is set**
**# It specifies the location of a user's home directory (from the client**
**# point of view)**
**;   logon drive = H:**
**#   logon home = \\%N\%U**
**# It specifies the script to run during logon. The script must be stored**
**# in the [netlogon] share**
**# NOTE: Must be store in 'DOS' file format convention**
**;   logon script = logon.cmd**
**# This allows Unix users to be created on the domain controller via the SAMR**
**# RPC pipe.  The example command creates a user account with a disabled Unix**
**# password; please adapt to your needs**
**; add user script = /usr/sbin/adduser --quiet --disabled-password --gecos "" %u**
**# This allows machine accounts to be created on the domain controller via the **
**# SAMR RPC pipe.  **
**# The following assumes a "machines" group exists on the system**
**; add machine script  = /usr/sbin/useradd -g machines -c "%u machine account" -d /var/lib/samba -s /bin/false %u**
**# This allows Unix groups to be created on the domain controller via the SAMR**
**# RPC pipe.  **
**; add group script = /usr/sbin/addgroup --force-badname %g**
**############ Misc ############**
**# Using the following line enables you to customise your configuration**
**# on a per machine basis. The %m gets replaced with the netbios name**
**# of the machine that is connecting**
**;   include = /home/samba/etc/smb.conf.%m**
**# Some defaults for winbind (make sure you're not using the ranges**
**# for something else.)**
**;   idmap uid = 10000-20000**
**;   idmap gid = 10000-20000**
**;   template shell = /bin/bash**
**# Setup usershare options to enable non-root users to share folders**
**# with the net usershare command.**
**# Maximum number of usershare. 0 (default) means that usershare is disabled.**
**;	usershare max shares = 100**
**# Allow users who've been granted usershare privileges to create**
**# public shares, not just authenticated ones**
**	usershare allow guests = yes**
**	username map = /etc/samba/smbusers**
**	security = user**
**;	encrypt passwords = yes**
**;	guest ok = no**
**;	guest account = nobody**
**#======================= Share Definitions =======================**
**# Un-comment the following (and tweak the other settings below to suit)**
**# to enable the default home directory shares. This will share each**
**# user's home directory as \\server\username**
**;[homes]**
**;   comment = Home Directories**
**;   browseable = yes**
**# By default, the home directories are exported read-only. Change the**
**# next parameter to 'no' if you want to be able to write to them.**
**;   read only = yes**
**# File creation mask is set to 0700 for security reasons. If you want to**
**# create files with group=rw permissions, set next parameter to 0775.**
**;   create mask = 0700**
**# Directory creation mask is set to 0700 for security reasons. If you want to**
**# create dirs. with group=rw permissions, set next parameter to 0775.**
**;   directory mask = 0700**
**# By default, \\server\username shares can be connected to by anyone**
**# with access to the samba server.**
**# Un-comment the following parameter to make sure that only "username"**
**# can connect to \\server\username**
**# This might need tweaking when using external authentication schemes**
**;   valid users = %S**
**# Un-comment the following and create the netlogon directory for Domain Logons**
**# (you need to configure Samba to act as a domain controller too.)**
**;[netlogon]**
**;   comment = Network Logon Service**
**;   path = /home/samba/netlogon**
**;   guest ok = yes**
**# Un-comment the following and create the profiles directory to store**
**# users profiles (see the "logon path" option above)**
**# The path below should be writable by all users so that their**
**# profile directory may be created the first time they log on**
**;[profiles]**
**;   comment = Users profiles**
**;   path = /home/samba/profiles**
**;   guest ok = no**
**;   browseable = no**
**;   create mask = 0600**
**[printers]**
**	comment = All Printers**
**	browseable = no**
**	path = /var/spool/samba**
**	printable = yes**
**;	guest ok = no**
**	create mask = 0700**
**# Windows clients look for this share name as a source of downloadable**
**# printer drivers**
**[print$]**
**	comment = Printer Drivers**
**	path = /var/lib/samba/printers**
**;	guest ok = no**
**# Uncomment to allow remote administration of Windows print drivers.**
**# You may need to replace 'lpadmin' with the name of the group your**
**# admin users are members of.**
**# Please note that you also need to set appropriate Unix permissions**
**# to the drivers directory for these users to have write rights in it**
**;   write list = root, @lpadmin**
**[Documents]**
**	path = /home/mj/Documents**
**	writeable = yes**
**	valid users = mj**
From the looks of your screenshot, that doesn’t look like Caja at all, I’d guess Nautilus, the file manager used in regular Ubuntu.
You can check this by going to HelpAbout on the menu bar.
If it is Nautilus, the package you’d need instead is nautilus-share.
I have both installed and neither work for file sharing
I see that browseable is commented out, try removing the ; and restart samba.
So it should look like this:
 [Documents]
	writeable = yes
	browseable = yes
	valid users = mj**
