I'm running Ubuntu-MATE 1804.4. I'd like to be able to use "Startup Applications" (or any other convenient method) to have 3 open term sessions when I boot up.
I've done this before, but don't remember exactly how. (Also, some of the commands I used for this in older MATE versions don't work anymore).
One term session would simply be open to my own machine's shell prompt. The command to put in "Startup Applications" for this is simple:
/usr/bin/mate-terminal title=<user@localbox> geometry=205x65+0+28
(The "+0+28" part of the geometry setting, however, has no actual effect on the placement of the term window for me right now, I don't know why.)
The other 2 term windows would be, upon boot-up, showing me the prompt of my ISP 1 (in one term-window) and ISP 2 (in a 2nd term window) that I have ssh'd into.
As I recall, what I did previously in "Startup Applications" was, I had to name them something like "blah.desktop", "blah.desktop.desktop" and "blah.desktop.desktop.deskotp" to distinguish them from each other, as they all started with the command /usr/bin/mate-terminal
Does anyone know what the command-strings one would put in the command-boxes of 3 separate "Startup Applications" entries (and the naming convention one would use for the 3 entries)?
