HOW can I enable “Enable Animations” at MATE tweak?
Compiz is working with Animations
Emerald Theme Manager is working, too.
Please help, thanks!
Hi @mate2go, When Compiz is selected that setting is grayed out because compiz-config-settings-manager (CCSM) is in control of animations and their settings. Same for other grayed settings. I hope that makes sense.
ah, ok Thanks for the infoformation.
