Dear all,
I experience some font rendering problems as shown in the screenshots below.
Does someone else have those or does someone know I can resolve those?
Thank you,
Robert
Blurry bold font in image viewer and PDF reader
Font window border problem
Interesting, I think this is the same bug I described here:
I hadn't realized this might affect other applications too.
A good first step would be to register yourself as affected on the bug report and maybe contribute your screenshots. :]
I will add my screenshots. Thank you, @ouroumov .
lah7
18 April 2017 12:40
4
From the bug report, I see it’s affecting 17.04 “Zesty”. Which graphics and drivers do you use?
Hello @lah7 ,
Indeed I am on 17.04. Does this help?
orschiro@x230:~$ sudo lshw -c video
[sudo] password for orschiro:
*-display
description: VGA compatible controller
product: 3rd Gen Core processor Graphics Controller
vendor: Intel Corporation
physical id: 2
bus info: pci@0000:00:02.0
version: 09
width: 64 bits
clock: 33MHz
capabilities: msi pm vga_controller bus_master cap_list rom
configuration: driver=i915 latency=0
resources: irq:29 memory:f0000000-f03fffff memory:e0000000-efffffff ioport:5000(size=64) memory:c0000-dffff
lah7
18 April 2017 18:13
6
It does, thanks You’re using Intel graphics , this would be good information to include in the bug report.
I’m not running 17.04 so I can’t confirm whether I have the same font rendering issue on my NVIDIA card, but if this bug can’t be replicated on non-Intel graphics, it could indicate a bug in Intel’s drivers.
I will add this information to the bug report then!
