After I restart my computer and login I get a software problem
Hi, @Travis_Brown and welcome to the Ubuntu MATE Community!
Hi @Travis_Brown, and welcome! I suspect this is a permissions problem. The first two messages suggest a failure implementing SAP (a commercial program) and the second points to a pam (privileged access management) problem. I suspect the two are linked. Can you tell us what you are trying to do?
What is the output of:
sudo service bluetooth status
Also; what system are you running MATE on? The output of:
inxi -MExz
would also be useful - this prints info about the machine and the bluetooth devices.
This isn't correct. The first two relate to failing to initialise "SIM access profile" for the system's bluetooth device(s); which may affect compatibility with other bluetooth devices.
I stand corrected, thanks.
