How to activate keyboard shortcuts
Please, anybody could explain how to activate keyboard shortcuts in ubuntu MATE 19.10. I can't use them since I have upgrade from 19.04. For example, nothing happens when I press "Ctrl + Alt + T" to open a terminal, neither when I press "alt" + "F2", to execute a command...
Thanks,
Fran.
You can check the keyboard shortcuts in the Control Center.
Click Menu > Preferences > Keyboard shortcuts.
Do you still see the shortcuts there?
Ok, I understand. Now, I can add new shortcuts.
Thank you very much!
Fran.
