Hi
is anybody can help about to activate php7 on my U Mate.
I install it by after trying a file such as index.php there is no results.
thanks for help
Bartonella
Hi
thanks for help
Bartonella
This is a good tutorial on how to install a LAMP (Linux Apache2 MySQL PHP) on Ubuntu 16.04. It also works on Ubuntu MATE.
Thanks for that
i got trouble with
mysql_secure_installation
Enter current password for root (enter for none): (
I press enter and here is the message
ERROR 1698 (28000): Access denied for user ‘root’@‘localhost’
any idea ?
Did you enter a password for root when installing MySQL?
Then you have to use that one.
in webmin i saw my passwd
i type the sameone in putty when asked by always the same message
i create with webmin a new use with same permissions as root and it works when i want to connect
what the mess ?
thanks
