if I slide the mouse over a selection field then I can change the content with the mouse wheel.
For example:
in [control center] > [display]:
if I slide over the resolution button I can change the monitor resolution with my mouse wheel.
That’s a nice feature, but:
I need to change it a little bit:
I would like to press a key additionally, may be ‘CTRL’ or ‘ALT’
Is this possible?
Where can I change this behaviour?
Many thanks
