How to CHECK if SPECTRE v2 Patch is enabled in UbuntuMate 18.04
Hi!
How can I check if SPECTRE v2 Patch and so on is enabled in UbuntuMate 18.04?
dmesg | grep -i spectre
To list types of vulnerabilities:
ls /sys/devices/system/cpu/vulnerabilities
To see status of vulnerability workarounds for above list:
cat /sys/devices/system/cpu/vulnerabilities/*
Have you tried the script at github?
thanks!
On my system, Spectre-patch is enabled…
