How to copy a large mkv file to a usb drive
hello can anyone tell me how I can copy a large mkv file to a usb drive. tried to do it with copy and paste said the file is to big. the file is about 26 gb and my usb drive is 128gb.
please help!
Hi @redgreen1965. I’ll bet you are fighting the 4GB filesize limitation of FAT32 which seems to be the universal default. I don’t think there’s a quick solution without reformatting the USB Flash drive to something like NTFS (for Windows compatibility) or EXT4 (only Linux).
ok thank you I will try that
