How to create a MIME-file for .war archive icon (Engrampa Archiver)?
Hi!
I use "Engrampa Archiver" to compress and de-compress files.
When I want compress files with ".war" The icon left is missing. [after upgrade to UM 20.04 LTS]
See screenshot (left icon - is missing)
In which folder are the icons stored for ".rar / .tar / .war / .zip and so on"?
Maybee is that in this folder?
/usr/share/icons/Humanity/mimes@2/24
gnome-mime-application-icon for the .war archive file.
Can someone tell me to fix the missing icon on compress-action?
Did a test and copied "gnome-mime-application-x-jar.svg" icon to another folder, renamed it to "gnome-mime-application-x-war.svg" and copied it back to the mime folder but the icon is still missing.
Any idea?
I copied all mime-type icons from "/usr/share/icons/Humanity/mimes@2/24" to "/usr/share/icons/my-theme"
Now the missing icon changed, it's still wrong, want an archive icon like 7zip or jar.
See picture:
at "/usr/share/mime/application" there is no "x-war.xml" :frowning:
Can someone explain me how to create a mime file for Engrampa Archiver for that .war icon?
I give up and went back to "File-Roller".
Removed file archiver "Engrampa".
