Hi!
I got this message in Log-File Viewer:
caja: Libgcrypt warning: missing initialization - please fix the application
How can I fix that?
Hi!
How can I fix that?
This lib has many dependencies and functions… Try this…:
Install the package manager “sudo apt-get install synaptic”.
Open the synaptic and search by name “libgcrypt20”, right click and select reinstall, go to apply in the top.
hmm, these packages are installed:
libgcrypt20
libgcrypt20-dev
libgcrypt20:i386
Your system is 32-bit? If it’s 64 you’re having fun with apt-get kkkk
The libgcrypt20-dev is not default, try reinstall or remove.
Good Look o/
My system is 64bit.
I re-installed it. Error-message is gone.
