Hi, I have MATE Desktop Environment 1.12.1. latest Ubuntu Mate on Odroid XU4.
How can I make Clocks timer always on top or whatever so that it sounds regardless of which workspace is active?
Thanks!
Fairly certain Mate has a small round button at the top left corner of the window, which when clicked has the option to allow you to do that⌠in Xfce itâs named âAlways on topâ and when active to disable it, the option becomes âsame as other windowsâ
Thx. I wasnât aware of that! In clocks it doesnât exist though. Iâll look for another app unless s.o. has an easy solution
If you âright clickâ on the title bar of a window, you have the options:
âAlways on Topâ
âAlways on Visible Workspaceâ
Is this what you are looking for?
clocks doesnât have that but thanks!
Alarm clock has this in the menu and works!
