How to stop need for sign-in after suspend
It is very annoying to have to sign-in after every suspend session. I asked not to be required to sign-in on start but did not see the choice given for suspend. I know it is possible to stop this. Is there anyone out there that knows what to do?
Thanks,
Glen
System, Preferences, Look and Feel, Screensaver, uncheck “Lock screen when screensaver is active”
Untried by me, but there are some dconf settings.
Also a LOCK_SCREEN setting in /etc/default/acpi-support that you can comment out.
I do not use suspend so you will have to see what works :slight_smile:
Thanks it seems to work. :slight_smile:
Glen
Which one :slight_smile:
