Hello, is it possible to install HUD in ubuntu mate 16.04 ?
There is a package only for 16.10 but you can compile it from source . You can compile it yourself .If you compile it from source ,do not use
make install
instead use
checkinstall
This way the package will be created and can easy be removed from synaptic .
For more info on checkinstall see here.
thanks
And we’ve dropped mate-hud
from 16.10 because testing revealed some serious issues we won’t have time to address in time for final
We will revisit this feature in 17.04.
