I have problems trying to install Wine
Hello,
So, I'm a noob when it comes to Linux (installed it today) and I wanted to install Wine on it. Everything went ok untill I got to this command :
sudo apt-get install --install-recommends winehq-staging
this error appears
E: Malformed entry 1 in list file /etc/apt/sources.list.d/wine.list (Component)
E: The list of sources could not be read.
Can anyone help me ?
Hello, @XrayMan19.
Show us the full, unabridged contents of the file /etc/apt/sources.list.d/wine.list. Otherwise, we have no idea what the issue is.
ALSO: After you paste the contents of that file into a post here, and before you hit the "Reply" button below, please select that text and click the </> button just above the text area. If you don't do that, the sources.list file will be very difficult to read, ideed. Ask me how I know that. :wink:
run this command in the terminal
sudo pluma /etc/apt/sources.list
and look at towards the bottom of that file you should see entries that should look like this
deb Index of /wine-builds/ubuntu focal main
#deb-src Index of /wine-builds/ubuntu focal main
My Wine list are on the main sources.list not in the sources.list.d folder
I used these instructions without issue.
One difference is that these intructions use:
sudo apt install --install-recommends winehq-stable
I think I managed to repair it myself. The problem was that the word"main" was on the second row, not the first near the other text
deb https://dl.winehq.org/wine-builds/ubuntu/ focal main
Also if u dont mind could u check my source.list so you can see if I screwed up any other files? Thnaks in advanced!
# deb cdrom:[Ubuntu 20.04.2.0 LTS _Focal Fossa_ - Release amd64 (20210209.1)]/ focal main restricted
# See http://help.ubuntu.com/community/UpgradeNotes for how to upgrade to
# newer versions of the distribution.
# deb http://archive.ubuntu.com/ubuntu focal main restricted
# deb-src http://ro.archive.ubuntu.com/ubuntu/ focal main restricted
## Major bug fix updates produced after the final release of the
## distribution.
# deb http://archive.ubuntu.com/ubuntu focal-updates main restricted
# deb-src http://ro.archive.ubuntu.com/ubuntu/ focal-updates main restricted
## N.B. software from this repository is ENTIRELY UNSUPPORTED by the Ubuntu
## team. Also, please note that software in universe WILL NOT receive any
## review or updates from the Ubuntu security team.
# deb http://archive.ubuntu.com/ubuntu focal universe
# deb-src http://ro.archive.ubuntu.com/ubuntu/ focal universe
# deb http://archive.ubuntu.com/ubuntu focal-updates universe
# deb-src http://ro.archive.ubuntu.com/ubuntu/ focal-updates universe
## team, and may not be under a free licence. Please satisfy yourself as to
## your rights to use the software. Also, please note that software in
## multiverse WILL NOT receive any review or updates from the Ubuntu
## security team.
# deb http://archive.ubuntu.com/ubuntu focal multiverse
# deb-src http://ro.archive.ubuntu.com/ubuntu/ focal multiverse
# deb http://archive.ubuntu.com/ubuntu focal-updates multiverse
# deb-src http://ro.archive.ubuntu.com/ubuntu/ focal-updates multiverse
## N.B. software from this repository may not have been tested as
## extensively as that contained in the main release, although it includes
## newer versions of some applications which may provide useful features.
## Also, please note that software in backports WILL NOT receive any review
## or updates from the Ubuntu security team.
# deb http://archive.ubuntu.com/ubuntu focal-backports main restricted universe multiverse
# deb-src http://ro.archive.ubuntu.com/ubuntu/ focal-backports main restricted universe multiverse
## Uncomment the following two lines to add software from Canonical's
## 'partner' repository.
## This software is not part of Ubuntu, but is offered by Canonical and the
## respective vendors as a service to Ubuntu users.
# deb http://archive.canonical.com/ubuntu focal partner
# deb-src http://archive.canonical.com/ubuntu focal partner
# deb http://archive.ubuntu.com/ubuntu focal-security main restricted
# deb-src http://security.ubuntu.com/ubuntu focal-security main restricted
deb http://archive.ubuntu.com/ubuntu focal-security universe
# deb-src http://security.ubuntu.com/ubuntu focal-security universe
# deb http://archive.ubuntu.com/ubuntu focal-security multiverse
# deb-src http://security.ubuntu.com/ubuntu focal-security multiverse
# This system was installed using small removable media
# (e.g. netinst, live or single CD). The matching "deb cdrom"
# entries were disabled at the end of the installation process.
# For information about how to configure apt package sources,
# see the sources.list(5) manual.
# deb https://dl.winehq.org/wine-builds/ubuntu/ hirsute main
# deb-src https://dl.winehq.org/wine-builds/ubuntu/ hirsute main
# deb https://dl.winehq.org/wine-builds/ubuntu/ focal main
# deb-src https://dl.winehq.org/wine-builds/ubuntu/ focal main
# deb http://www.duinsoft.nl/pkg debs all
deb http://archive.ubuntu.com/ubuntu focal main universe restricted multiverse
deb-src http://archive.ubuntu.com/ubuntu focal universe main multiverse restricted
deb http://security.ubuntu.com/ubuntu/ focal-security universe main multiverse restricted
deb http://archive.ubuntu.com/ubuntu focal-updates universe main multiverse restricted
deb http://archive.ubuntu.com/ubuntu focal-backports universe main multiverse restricted
# deb http://extras.ubuntu.com/ubuntu focal main
# deb-src http://extras.ubuntu.com/ubuntu focal main
I don't see anything else wrong with the file.
Ok. Thanks for the help!
