Indicator Applet Icons
I just installed the Snap version of VLC and in the indicator section, there isn't a VLC icon, just the red circle icon. Is there a place I can give the indicator applet an image so I get the VLC cone icon?
When you right click on the ‘red circle’ and select properties you can select the icon on the left and select a file location for the VLC icon. If you can’t find your VLC icon its easy to download one and store this somewhere in your personal folders.
When right-clicking there is no option to select properties. It only brings up options for the Indicator Applet Complete.
