Digging around the net Trying this Cmd and that Cmd to get the Last system Msg’s to display in the terminal I cam across on that kind of works and would like to get some help on making it better OR if you have a better way to get these Msg’s do display in the terminal I would greatly appreciate it.
This is what I ran across
dbus-monitor "interface='org.freedesktop.Notifications'" | \
> grep --line-buffered "member=Notify\|string"
this gives me something like this
method call time=1534045699.046024 sender=:1.107 -> destination=org.freedesktop.Notifications serial=814 path=/org/freedesktop/Notifications; interface=org.freedesktop.Notifications; member=Notify
string "Chromium"
string "file:///tmp/.org.chromium.Chromium.8RQiGV"
string "96% - Remote.Desktop.Manager.Enterprise.13.6.7.0.rar"
string "166.18 MB of 172.31 MB
string "24"
string "Open Manager"
string "default"
string "Activate"
string "urgency"
string "desktop-entry"
variant string "chromium-browser"
string "image_path"
variant string "/tmp/.org.chromium.Chromium.HKRJBp"
string "image-path"
method call time=1534045702.047663 sender=:1.107 -> destination=org.freedesktop.Notifications serial=815 path=/org/freedesktop/Notifications; interface=org.freedesktop.Notifications; member=Notify
string "Chromium"
string "99% - Remote.rar"
string "170.89 MB of 172.31 MB
string "25"
string "default"
string "Activate"
string "urgency"
string "image_path"
variant string "/tmp/.org.chromium.Chromium.veuuOm"
string "image-path"
which is almost what I want. (I think) I love information and I like to know what is going on or if I missed a notification while I was a way from the box
Will / is this the best option to get this information?
this works but i’m not sure it is coded correctly.
(Not a Coder)
Thanks
