You can use this to insert text into documents, etc. using a keyboard shortcut.
Just make sure that subprocess.call contains whatever file manager you are using.
Is there an easier way to indent code other than manually?
It’s tedious doing so with a large file.
#!/usr/bin/env python3
import os
import subprocess
home = os.environ[“HOME”]
directory = home+"/.config/snippet_paste"
if not os.path.exists(directory):
os.mkdir(directory)
create file list with snippets
files = [
directory+"/"+item for item in os.listdir(directory)
if not item.endswith("~") and not item.startswith(".")
create string list
strings = []
for file in files:
with open(file) as src:
strings.append(src.read())
create list to display in option menu
list_items = [“manage snippets”]+[
(str(i+1)+". “+strings[i].replace(”\n", " “).replace
(’”’, “’”)[:20]+"…") for i in range(len(strings))
define (zenity) option menu
test= ‘zenity --list ‘+’"’+(’" “’)
.join(list_items)+’”’
+’ --column=“text fragments” --title=“Paste snippets Ctrl V”’
process user input
try:
choice = subprocess.check_output(["/bin/bash", “-c”, test]).decode(“utf-8”)
if “manage snippets” in choice:
IMPT!! Use whatever file manager I am using
subprocess.call(["thunar", directory])
else:
i = int(choice[:choice.find(".")])
# copy the content of corresponding snippet
copy = "xclip -in -selection c "+"'"+files[i-1]+"'"
subprocess.call(["/bin/bash", "-c", copy])
# paste into open frontmost file
paste = "xdotool key Control_L+v"
subprocess.Popen(["/bin/bash", "-c", paste])
except Exception:
pass
