Install Bionic Beaver on a flash drive
I am trying to install (not just a bootable for testing) 18.04 Bionic Beaver on a USB flash drive. So I could run it in parallel, upgrade wit the changes and even install a few programs… while still running 17.10 for work purposes on my SSD.
But I can’t seem to have it to work.
Probably a basic tiny detail…
I did it with 17.10 when it launched and finally did the full upgrade on my SSD. Just trying to replicate same, here.
Any link to good info page ? All I find relates to 16.04 & al and ask for swap…etc
Thanks
Hello Watford! I think you are looking for a USB install with “persistence” , the ability to continue to add to the USB, distinct from your main drive. I think you ought to look at creating a USB linux drive with unetbootin. Sadly, it won’t work with my mac OSX, but the literature says it’ll work with Linux and Windows.
I love Etcher for it’s ease of use, but unetbootin will probably do the trick for you. Be sure to use a fairly large USB drive.
Did it. No persistence. will try otherwise
Etcher - doesn’t provide for install with persistence. It starts, no options possible.
Unetbootin - same as above
Taking a step into windows to use Universal-USB-Installer…
Windows says that my USB key has no space (while it shows a full usable 33G under UM) … And UUI option to create persistence is frozen, because of that windoze reading of the key.
Well…
Still in Windows I decided to use Rufus… it did read the volume (yeah!) and I installed (no persistence)
Then I went and used UUI again and this time around it did read the volume (installed using Rufus) and I re-installed, this time with persistence. Seems to work so far… writing this using Bionic from the USB. Will keep you posted, since now will get into trying to get some updates.
W
I have never got Ubuntu to run on persistence in the 11 years I have been using it.
So I shall be happy to hear your results :slight_smile:
It did work at the end. With version Feb 6 of the UM ISO image.
Then did an update on the USB and it seems it completed well.
Will tweak and use a bit - just to check vs 17.10. Still working from 17.10 on my SSD though, with Win10 on the laptop HD (haven’t used windoze in any work fashion since last summer; except for things I can’t figure how to handle otherwise - like the above)
Will comeback here with anything that’s worth notice or shout for help… :slight_smile:
W
coolbeans dude.
So just so I know - would a 16GB flash drive/ USB stick using Rufus be Okay to put persistent Ubuntu-Mate 16.04 on-to, to thereby make fully operational for say a year or so, and learn to code on a ‘generic’ windows PC desktop ?
Oh, I didn’t say thanks.
Thankyou dude :relaxed:
I don’t know if Rufus would be OK for including a persistence space. If you read me above, I went with UUI for that reason.
16G may be fine, bit if I were you, I’d go with a 32G flash drive if you are to use it for a whole year - techies here may be of a different opinion.
