Hello,
when i choose the installation option "minimal system", is it possible to get the sshd (openssh-server) with that installation? I specifically ask for the "desktop" install 20.04 LTS, not the server.
regards
EDV
Hello,
regards
EDV
I don't see why not
Just install it after installation of the minimal system:
sudo apt-get install openssh-server
Maybe its my bad english, but i know how to install packages after the installation is ready and the system is running.
My point was to get sshd with the installation / setup of the operating system.
(Dont want to use the term unattanded install)
regards
EDV
In that case, i'll have to answer with a resounding NO
sshd is not a part of the standard desktop install and also not a part of the minimal install
only the server install gives you that option.
Sorry.
