Hello Mate community.
Some time ago I installed Ubuntu Mate on my PC as a dual boot on a separate ssd to try it out. I was very pleased and wanted to let my girl have a try as well.
She diddnt have a spare ssd so I wanted to install it on the existing ssd, next to Windows 8. Obviously W8 had to stay on the ssd to go back to. Not knowing the exact procedure I went ahead with my own best plan.
I split the ssd to make a separate partition of 40G.
Started the installation from a data stick with Ubuntu Mate on it for installation.
To choose the right option was not totally clear for me. Install UM next to Windows or as a separate installation. Because I had made a separate partition for it I choose NOT for the option 'next to other OS.
So I installed it as a separate installation.
After reboot it started into Grub. From here I could go to Ubuntu and that worked just fine.
There was however no option for going to Windows !? I could not just close Grub and let the boot procede to Windows.
I tried to find a way to change Grub so that I could get it to boot to W8 but could not find it or it was to difficult. I think that I could insert a line by hand, but that is to hard for my minimal of Linux skills.
So I found a way to get rid of Grub, with the Installation CD from Windows, which I did.
Then I had Windows back but no Linux because I deleted Grub.
My plan then was to delete the whole Linux partition and let the installation of Linux split the partition anew and install Linux next to Windows, so it would appear in Grub.
So I tried that and I ran into unclarities in the installation. The partition where windows was installed was no longer marked as a windows partition, probably due to the former installation of Linux and/or Grub and the removal thereof.
I wanted to then split the partition where Windows was installed, during installation, so that it would be seen in Grub.
this was a very obscure process in which it kept saying the partition was to small for the installation, until I made it about 72 GB !
14 I also marked it for formatting linux filesystem ext 4 (?) so it would be the right type for the Linux. -
It was all so obscure and unclear what would happen so I decided NOT to start the installation. I didn t trust it would be safe. (windows not being marked on the windows partition etc).
When I rebooted I got the shock of what I was afraid for. The new partition was already made! Right over the Windows partition. The whole of W8 was gone!
I hadn t started the installation and still it already created the partition and formatted it to Linux Ext4. Without warning me or asking if this is really what I wanted !
During this part of the installation it was totally not clear if it was getting the info of what it was later to do or if it was going to do things right away!
And it was to me also not clear what the right way ahead was for my installation and what everything encompassed.
Apparently a deadly combination.
So now I am going to install Windows 10 first. Then I am still interested in getting Linux as a try for her but I am not going to go ahead again like I did, however, it must be much clearer for me what to do, otherwise I will let it pass.
I hope some of you can shed some light on what went wrong and what would be the right way to approach the installation.
JR
