Hi everybody,
I tried to install Photoshop CS2 with Wine but it doesn’t work. After the first installation mirror it shuts down. What can I do? Thx!
Hi everybody,
You could try using one of the Wine type tools that help with installs, like playonlinux. You could also try crossover linux and see if that will do it. Crossover is proprietary though. But they have a free trial so you can check out and see if it works first.
You could also try to learn the gimp, krita, mypaint, or pinta which are all in the repos already.
Regards,
Tim
