Invalid screenshot filename error
Everytime I take a screenshot of my desktop with mate-screenshot and try to save it with the default filename, I get an error saying that the screenshot has an invalid filename.
That happens because mate-screenshot’s default filename includes a timestamp with colons, which are identified as invalid characters.
So, is there a way to change the default filename, i.e. have a timestamp without colons?
This seems to be a bug that was resolved in standard Ubuntu, but has not yet filtered down to Mate.
I would recommend installing gnome-screenshot and using it for now.
https://bugs.launchpad.net/ubuntu/+source/gnome-screenshot/+bug/1054808
https://bugs.launchpad.net/ubuntu/+source/gnome-utils/+bug/1050261
Uh, I’m running Ubuntu MATE 16.04 and I don’t have that problem, colons or not. :x
I also run 16o4 without the problem. Just my findings :slight_smile:
It’s fixed it the git repo. The source now uses ‘-’ (dashes) instead of ‘:’ (colons)
Filed bug 1579447 on Launchpad with a patch. Hopefully it’ll get included in an update.
Thank you for your replies! I will mark this as solved.
@ramblinman41, switch to hyphens will automatically be implemented as MATE 1.14 is released/adopted. :slight_smile:
Yes, I was browsing the git tree on it but that won’t be in the LTS release, I don’t think.
