Is rendering my computer completely unusable MATE's fault or LXQt?
Is rendering my computer completely unusable MATE’s fault or LXQt?
The scenario:
I install a fresh MATE 18.04.1. Works fine after reboot.
I install LXQt to try it out.
$ sudo apt-get update
$ sudo apt-get install lxqt openbox
I logout, get the login screen, I choose the lxqt option from the dropdown mentu to try it out.
I get this window:
“Welcome to LXQt
Please slect your default Window Manager.”
and the options are:
“Other… Chose your favorite one”
And that’s the only option. What the hell do I do with that? Underneath:
“You will be able to change this at any time through Preferences -> Session Settings -> Basic Settings.”
With one button “OK”
There’s no cancel button. That’s the only button.
What do I do? I guess I’ll reboot, right. I reboot. I get the same window. (I guess because in the MATE install I told it to auto-login.)
Thus my computer is completely useless. What is my other recourse but to reinstall MATE. I reinstalled MATE. Here I am. Good thing I hadn’t set it all up and installed stuff and THEN thought hey gee golly maybe I’ll try another window manager.
(I’ve been a lamp developer for 20 years and I did crtl-alt-F4 to get a command prompt, but hey, pretend I wasn’t; pretend I was a beginner or intermediate. So in fact, I didn’t bother trying to needle around to fix it, it’s not worth my time. Why should I fix some shitty distro and/or window manager.)
Which brings me to my original question:
Who’s at fault here? Is that MATE’s fault, or is that LXQt’s fault?
Which one should be responsible for not providing me a cancel button? I want to know who to avoid forever.
Thank you,
That would be an LXQT issue, since MATE doesn’t have those settings mentioned in the window, nor the window itself anywhere in its code, as far as I know.
Seems like LXQT needs a different window manager that is not automatically pulled in the dependencies?
Thanks @vkareh I thought so. BTW I posted this same post on the lxqt forum too and my account was locked “pending” mode for a while but that might just be automatic, and to their credit it’s approved now. The responses so far are predictable- some tapdancing, some laughably ignorant (“Not our problem”), but at least there was something underneath it that was an attempt to deal with it.
