Is Ubuntu-mate can solve the missing plugin problem of GStreamer 0.1?
Dear Friends,
I have a pygtk2 application which work fine upto ubuntu 15.10 and new release (16.04) they discontinue the support of ‘mad’ plugin in GStreamer 0.1. So my application not work on it. Using Ubuntu-mate any chance to fix this issue.
Waiting for a fast solution
Hi @anespa,
did you mean “bad” plugins, you can search for them here:
https://pkgs.org/download/libgstreamer-plugins-bad0.10-0
Hi @wolfman,
I mean “ugly” plugins, and looking for latest 16.04 Ubuntu (for Gstreamer 0.1) support.
use the 15.10 packages, they should work, simply install them with Gdebi:
https://pkgs.org/download/gstreamer0.10-plugins-ugly
Hi @wolfman,
I tried using that package using 2 ways:
sudo apt-get install libgstreamer-plugins-bad0.10-0
then got error as
Reading package lists… Done
Building dependency tree
Reading state information… Done
Package gstreamer0.10-plugins-ugly is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
E: Package ‘gstreamer0.10-plugins-ugly’ has no installation candidate
and then download the .deb and try to install Gdebi
got error as
Error : Dependency is not satisfiable : libsidplay1
Trying to install libsidplay1 also not working…
any idea
Try the packages here, install with Gdebi!:
https://pkgs.org/download/libsidplay1v5
Hi @wolfman,
But when I try to install libsidplay1v5 got as it’s already installed as:
insight@insight-desktop:~$ sudo apt-get install libsidplay1v5
libsidplay1v5 is already the newest version (1.36.59-8).
libsidplay1v5 set to manually installed.
0 upgraded, 0 newly installed, 0 to remove and 39 not upgraded.
But still that problem of
exist.
Hi @wolfman,
I tried your solution in Debian 8.4.0 installation , by installing gstreamer0.10-plugins-ugly_0.10.19-2.1_i386.deb that error regarding ‘mad’ is gone. Thanks alot.
But there is another error message as:
Gtk-Message: Failed to load module “canberra-gtk-module”
Traceback (most recent call last):
File “”, line 1, in
File “/usr/lib/python2.7/site-packages/dbr/dbr.py”, line 22, in
main()
File “/usr/lib/python2.7/site-packages/dbr/dbr.py”, line 13, in main
r = reproductor.Reproductor()
File “/usr/lib/python2.7/site-packages/dbr/reproductor.py”, line 29, in init
conv = gst.element_factory_make(“audioconvert”, “converter”)
gst.ElementNotFoundError: audioconvert
How to fix this ?
any idea
Hi @wolfman,
Got that too by install good library. The remaining is “alsasink” in which library it came.
already installed base,good,bad and ugly …
any idea?
Try installing the following?:
https://pkgs.org/download/gstreamer1.0-alsa
I have no idea about “alsasink” as it doesn’t show in the packages lists at https://pkgs.org/ !. :smiley:
