Keep theme when upgrade
Hello, when upgrade to an old LTS to the latest LTS, does the active theme used (GTK + icons) will be still used and active, after upgrade? In particular for theme downloaded, as Materia or Paper-icons.
Yes, the upgrade should not change your theme or icons that you have configured.
