My upgrades seem to go fine, until it gets to updating the kernel. I'm not sure how to fix this so that my kernel will upgrade to the latest. Here are the error messages from the terminal:
Processing triggers for initramfs-tools (0.131ubuntu19.1) ...
update-initramfs: Generating /boot/initrd.img-5.0.0-20-generic
I: The initramfs will attempt to resume from /dev/sda1
I: (UUID=97c5af9e-c68a-4c15-b73f-fca078d678fd)
I: Set the RESUME variable to override this.
mowest@C650:~$ uname -r
5.0.0-15-generic
Because of the mention of sda1, I would like to explain my partition scheme on sda which is a 128 Gig SSD.
/dev/sda1 - 1.9G Linux swap
/dev/sda2 - 94.1G Linux ext4, where Ubuntu Mate 19.04 is installed, boot flag on this partition.
/dev/sda3 - 23.3G Linux ext4, where Kubuntu 19.04 is installed, and the last system that installed Grub into the master-boot record of the drive.
I'm not sure if Ubuntu Budgie install messed things up by installing grub or perhaps the error messages above reveal a different issue. I don't remember this happening before when I have run two different Ubuntu versions on the same SSD.
