Keyboard and touchpad not working in Ubuntu MATE 15.10
I m new to linux.This is first time i installed linux and i installed as dualboot .keyboard and touchpad is not working.but they are working fine in windows 10. i m now using usb mouse with on screen kryboard, usb mouse is working .need help…
Please post your computer specs. This can be done using the terminal (Ctrl + Alt + t) and enter:
Code:
inxi -b
If you can boot into recovery mode, run "dpkg" (network cable connection required) per the update guide:
karthik@karthik-Satellite-C50-A:~/Desktop$ inxi -b
System: Host: karthik-Satellite-C50-A Kernel: 4.2.0-16-generic i686 (32 bit)
Desktop: MATE 1.10.2 Distro: Ubuntu 15.10 wily
Machine: System: TOSHIBA product: Satellite C50-A v: PSCG8G-05F00G
Mobo: Intel model: PT10F v: Type2 - Board Version
Bios: Insyde v: 1.20 date: 09/04/2013
CPU: Dual core Intel Core i3-3110M (-HT-MCP-) speed/max: 1199/2400 MHz
Graphics: Card: Intel 3rd Gen Core processor Graphics Controller
Display Server: X.Org 1.17.2 drivers: intel (unloaded: fbdev,vesa)
Resolution: [email protected]
GLX Renderer: Mesa DRI Intel Ivybridge Mobile x86/MMX/SSE2
GLX Version: 3.0 Mesa 11.0.2
Network: Card-1: Qualcomm Atheros QCA9565 / AR9565 Wireless Network Adapter
driver: ath9k
Card-2: Qualcomm Atheros QCA8172 Fast Ethernet driver: alx
Drives: HDD Total Size: 500.1GB (1.1% used)
Info: Processes: 166 Uptime: 5 min Memory: 406.0/1884.8MB
Client: Shell (bash) inxi: 2.2.16
And good morning :slight_smile:
I took a look around and have not hit on a solid answer for you, but did find a couple of bug reports and one (maybe) work-a-round.
https://bugs.launchpad.net/ubuntu/+source/linux/+bug/1325003
https://lists.launchpad.net/kernel-packages/msg64070.html
http://ubuntuforums.org/showthread.php?t=2241101
I have not hit on a keyboard solution :frowning:
I am having similar keyboard/trackpad issues. Now running UM18.04.2
inxi -b
System: Host: lordbaron-Satellite-L775D Kernel: 4.15.0-54-generic x86_64
bits: 64
Desktop: MATE 1.20.1 Distro: Ubuntu 18.04.2 LTS
Machine: Device: laptop System: TOSHIBA product: Satellite L775D v: PSK40U-07P00R serial: N/A
Mobo: PEGATRON model: TKBSS v: 1.50 serial: N/A
BIOS: American Megatrends v: 1.50 date: 10/18/2011
Battery BAT0: charge: 61.3 Wh 60.1% condition: 101.9/96.8 Wh (105%)
CPU: Dual core AMD A4-3305M APU with Radeon HD Graphics (-MCP-)
speed/max: 838/1900 MHz
Graphics: Card: Advanced Micro Devices [AMD/ATI] Sumo [Radeon HD 6480G]
Display Server: x11 (X.Org 1.19.6 )
drivers: ati,radeon (unloaded: modesetting,fbdev,vesa)
OpenGL: renderer: AMD SUMO2 (DRM 2.50.0 / 4.15.0-54-generic, LLVM 6.0.0)
version: 3.3 Mesa 18.0.5
Network: Card-1: Realtek RTL8188CE 802.11b/g/n WiFi Adapter
driver: rtl8192ce
Card-2: Realtek RTL810xE PCIE Fast Ethernet controller
driver: r8169
Drives: HDD Total Size: 256.1GB (22.2% used)
Info: Processes: 173 Uptime: 1 min Memory: 881.5/3419.6MB
Client: Shell (bash) inxi: 2.3.56
Seems to be something with the Toshiba laptops, every post I've found on this topic is a Toshiba.
Some of these laptops have a trackpad on/off button below the space bar, so try that first, along with alt+f9. both of these can turn the trackpad off.
What is happening with mine is the keyboard and trackpad work fine in bios setup, but when UbuntuMATE boots the NUM LOCK light turns off and the keyboard and trackpad are turned off.
If I update grub and reboot, then sometimes the keyboard begins working again, and will continue working until shutdown or long suspend.(Not a short suspend, that might be a clue)
