Keyboard issue after upgrade
Hi i am using below after update right half of keyboard converted to num keys u-4, j-1, m-0 so on please help
LENOVO3000-V200 Kernel: 4.4.0-53-generic i686 (32 bit gcc: 5.4.0)
Desktop: MATE 1.12.1 (Gtk 3.18.9-1ubuntu3.1)
Distro: Ubuntu 16.04 xenial
Machine: System: LENOVO (portable) product: 07648DJ v: LENOVO3000 V200
Mobo: LENOVO model: INVALID
Bios: LENOVO v: 65ET58WW (0.09 ) date: 02/01/2008
CPU: Dual core Intel Core2 Duo T8100 (-MCP-) cache: 3072 KB
flags: (lm nx pae sse sse2 sse3 sse4_1 ssse3 vmx) bmips: 8399
clock speeds: max: 2101 MHz 1: 1600 MHz 2: 1600 MHz
Graphics: Card: Intel Mobile GM965/GL960 Integrated Graphics Controller (primary)
bus-ID: 00:02.0
Display Server: X.Org 1.18.4 drivers: intel (unloaded: fbdev,vesa)
Resolution: [email protected]
GLX Renderer: Mesa DRI Intel 965GM x86/MMX/SSE2
GLX Version: 2.1 Mesa 11.2.0 Direct Rendering: Yes
Audio: Card Intel 82801H (ICH8 Family) HD Audio Controller
driver: snd_hda_intel bus-ID: 00:1b.0
Sound: Advanced Linux Sound Architecture v: k4.4.0-53-generic
Network: Card-1: Broadcom NetLink BCM5906M Fast Ethernet PCI Express
driver: tg3 v: 3.137 bus-ID: 05:00.0
IF: enp5s0 state: down mac: 00:0a:e4:cf:a2:8e
Card-2: Intel PRO/Wireless 4965 AG or AGN [Kedron] Network Connection
driver: iwl4965 v: in-tree: bus-ID: 06:00.0
IF: wlp6s0 state: up mac: 00:1f:3b:c6:a1:7b
Drives: HDD Total Size: 120.0GB (11.2% used)
ID-1: /dev/sda model: TOSHIBA_MK1246GS size: 120.0GB
Partition: ID-1: / size: 108G used: 11G (11%) fs: ext4 dev: /dev/dm-0
ID-2: /boot size: 472M used: 343M (77%) fs: ext2 dev: /dev/sda1
ID-3: swap-1 size: 1.60GB used: 0.24GB (15%) fs: swap dev: /dev/dm-2
RAID: No RAID devices: /proc/mdstat, md_mod kernel module present
Sensors: None detected - is lm-sensors installed and configured?
Info: Processes: 217 Uptime: 19 min Memory: 1030.1/1497.9MB
Init: systemd runlevel: 5 Gcc sys: 5.4.0
Client: Shell (bash 4.3.461) inxi: 2.2.35
I suggest that you use Google and search on “lock Fn key Lenovo”. Your function key may have become locked. Good luck max1.
Thanks Function keys work fine
The Fn key located just to the right of the leftmost Ctrl key. Your keyboard appears to have a locked down Fn key.
issue started after running update on 15 dec 2/16
I realize that the problem appeared after an upgrade. There may be some settings left over from your older OS that conflict with your MATE 16.04 upgrade. In order to duplicate the problem you reported in your initial post, I must press the NumLk key once and then hold down the Fn key as I use the mjkluiop7890 keys. Pressing the NumLk again restores the mjkluiop7890 keys to their proper state. That is why I characterized the problem as a locked function key.
I think that you should first try rebooting your machine to see if the keying problem persists. Then try logging into a guest session and see if the problem is still there. Another item to check is a BIOS setting.
Thanks
i am using MATE 16.04 for 2 months updating every week
my laptop doesnt have separate num pad
can i uninstall last update
Thanks Issue solved after I pressed num lock
Thanks So much!!
By the way My :/* and left control key does not work from the day I installed MATE 16.04
Is there any solution for that?
Hi @max1,
also make sure you have the right layout running (Control Centre > Hardware > keyboard > Layouts):
