Keyboard layout changes when double clicking mate menu
If I double click the menu (the one opens with the super key) or a window in the Window List (on The MATE Panel), the keyboard layout changes to the last option on the list of configured keyboard layouts.
Is this a bug or it configured to behave like that somewhere?
EDIT: deleted a bunch of old files and also deleted and recreated the keyboard style and it seems that the problem is gone. Maybe a bad keyboard configure file was causing some reload internally by some reason.
OP solved own problem!. :thumbsup:
Marked as solved in this thread because it requires at least one reply to do so!. :smiley:
can I suggest simple terminal command?
dconf reset -f /
