is it possible to put text beside the best answer button as it is being overlooked in many solved posts and although solved, there is no indication of that fact!.
Something like, āClick here to mark as solvedā or something similar please!.
I think thatās a good idea, something like āMark as Solvedā next to the iconā¦
The trouble is, itās not something that can be easily added. It would require some changes made to its source first.
For now, weāll need to educate our members with this post:
I thought I set this, but Regulars are now able to set solutions for any topic.
I am regular, I go every morning!. Thanks Luke.
Technically, it shouldnāt require changing any source except for the website. Couldnāt it be deterined in the site code to make a pseudochild for the āMark as solvedā button?
Iām pretty sure I can do this in less than a half-hour if I probe the site for what class creates the checkbox. It would be a dirty solution, but one nonetheless.
Technically possible, but definitely a dirty hackā¦ main problem is that changes would be lost when the software/container updatesā¦ Plus, I donāt have access to the siteās source itself.
If itās a patch in the plug-inās source, then it could be applied.
When I get some spare time, I might have a probe to implement it properly (with the option in settings) ā since itās open source, it can be contributed back to the wider community too.
