You requested opinions on what to salvage from your project. You can recategorize this as Uncategorized if you think that is wise. It has nothing to recommend I just didn’t think it was a Thoughts or Feedback category subject however.
You can edit your own posts. Click on the pencil icon next to the post title. There you can change anything about your post including its’ title and category. I’ve taken the liberty of changing the category for you. Why don’t you practice on this post?
All depends on the model of HP, age of the laptop (and availability of replacement parts). You might be able to find the pieces needed if it’s worth repairing, or sell the remainder of it for someone who needs to fix theirs (a good LCD can be quite handy on the used parts market, and sometimes a replacement case is needed for someone’s otherwise functional machine).
I know about the pain of rebuilding a laptop. I had to replace a charger board on a Dell Studio 17, and it turned out that was the first part put in the case when it was assembled. Which meant everything else had to come out of the case first, then all get correctly re-inserted. Six years later, I think it’s no longer charging the battery (even with a new one), so may have to replace it in the next year.
