LireOffice, Help with spell check, dictionary empty
Libreoffice spell check in my Mate 16.04 is not working. The dictiory at ~/.config/libreoffice/4/user/wordbook/standard.dct is 45 bytes (no dictionary. Libreoffice Help is no help. Where can I find specific help? Or can anyone help?
Which language do you need?
Dictionaries can be found here.
But I think Libre should use the system build in language/dictionary. Not sure…
HI @xaire,
open Control Centre > Personal > Language Support and let it run, you most likely don't have all the language packs installed!. :smiley:
