Location settings?
I just bought a new HP all in one PC that came shipped with windows. I decided to install Ubuntu in a dual boot situation.
This new device has GPS on it and in Windows 10 I was able to turn it off and tell no apps to use that feature. Is there a similar way to do this in Ubuntu Mate or instead would I just get prompted every-time? I am asking because I see no option for it on any menu.
Thanks in advance for any replies!
Hi :slight_smile:
You can disable it in bios :slight_smile:
I think it's a amazing feature to be requested. It's about privacy and security.
